bhowe408
Mar 15, 2023Aspirant
Nighthawk Mesh wifi extender EX8000 blinking red power light
My extender just stopped working about a week ago and every since has had a blinking red power light. All other led lights are blinking white. I can't get into mywifiext site to update the firmware. ...
Mar 16, 2023Guru - Experienced User
You can try recovering it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
- bhowe408Mar 16, 2023Aspirant
When I type in "cd desktop" it says that it can't find the path specified. It looks like this:
C:\users\myname>cd desktop
so then it can't read from the local file.
I'm not sure what I'm doing wrong. I downloaded the firmware file to my desktop and followed all the other steps.
- plemansMar 16, 2023Guru - Experienced User
did you watch the video? It walks you through how to use it
The video walks you through using a tftp client that you download. I did not try that. I was using the site that was provide using the command prompt screen, which is not included in the video (unless I'm looking at the wrong video)
The command prompt is not working, so if you have someone more direct on those instructions, that may be helpful. Otherwise, I may try downloading the third party tftp client and see if that works.
- plemansMar 17, 2023Guru - Experienced User
So your issue right now is getting to the proper command prompt?
I just tested on mine and it works fine.
Maybe screen snips of what you're doing and where you put things will help more
- bhowe408Mar 17, 2023AspirantWell, I went ahead and called netgear. They did some additional testing and it appears to be hardware related. I didn’t pay for them to do any software changes because they charge a lot and I can just get a new updated extender for just a little more. However, it won’t be netgear this time. They should support for life. If it was their update that didn’t finish all the way, which they will never admit, then their software support should just be free. I’m not convinced it’s hardware. They are a business. Blame it on hardware then the customer has to buy a new one. I’m convinced it’s a method to just make customers spend more money.
I looked online for other videos with command prompt lines to the desktop. Didn’t find them. I’m on windows 11. Maybe there is a difference. That said, I spent hours trying different things, searching, and calling netgear. It’s all part of their plan I’m sure. But my money will go elsewhere this time.
