rockyiv806
Nov 10, 2018Follower
Nighthawk Mesh with AC1900
I have the Nighthawk AC1900 modem/router in one. I have a spot in the house where it is not a dead zone but the internet signal drops down to between 1 and 2 bars. First off can I use any of the mesh...
Nov 10, 2018Guru - Experienced User
You should be able to use a mesh extender, placing it somewhere between the router and the spot with the weak signal. A triband extender will give the fastest speeds (assuming you place it someplace where you can use 5 Ghz to reach the Nighthawk).
There are other options, including using powerline (PLPW1000). That is less expensive than the mesh extenders.
You could also replace the Nighthawk with the Orbi CBK40 (which has a built in cable modem). Or get an RBK40, and deploy it as an access point (turning off the wifi in the Nighthawk). Orbi would of course be more expensive then the mesh extenders.
