ASHEET
Feb 12, 2022Aspirant
Nighthawk Mesh with Jio Router
Hi 1. I have a JioFiber Home gateway dual band router which has a Fiber Internet port. It has 4 LAN ports. It also supports Mesh network with Jio Mesh extender. 2. I recently received Netgear Night...
Feb 13, 2022Guru - Experienced User
No, you can't use the satellites with the Jio router/mesh.
but you can setup the netgear MR60 router in access point mode and connect the satellites to it.
You could either leave the Jio with its wireless on for a backup or to offload the netgear router or you could disable its wireless.
ASHEET
Feb 13, 2022Aspirant
I am able to successfully pair the Satellite with JioHOmeGateway as Jio has Mesh option and has its own Satellite option.
I was able to do it using WPS option on Jio and Netgear Satellite.
- plemansFeb 13, 2022Guru - Experienced User
that'd be the first time a netgear mesh solution has worked with others. could be because the MK60 and MK80 are built on the EasyMesh standard.
