DAC2248
Oct 04, 2019Aspirant
Nighthawk Model D7800 AND mesh extender
I have a Nighthawk model D7800 AC2600 and find that the wifi signal is poor in some home areas. Using the Netgear WiFi Analytics I get the following results: At the router itself - 70% At the TV r...
DAC2248
Hi plemans, many thanks for your message (I am unsure if this is the corect method of replying). I am trying to cover a distance about 25 metres, reasonably direct from my home office, glass sliding door to a balcony, reverse back into living area, dining area, then to TV room. I read the Toms guide, then logged into the EX6250 Extender, updated firmware. Read through the manual, adjusted a few setting, but cannot specify exactly. The end result, using the Netgear Home Testing app for androids I now get the following signal readings (which I believe ought to be ok - Home office = 100% Balcony & Living & Dining Room = 70% - 100% & TV Room (where the extender is = 100%. Certainly better signal strength than earlier. Thanks again.
The test will come in the morning when I cast some English football.
