gasman826
Nov 28, 2023Follower
NightHawk MR60 router won't sync to MS60 satellite via ethernet cable
My new Nighthawk MR60 router desk syncs to both MS60 satellites wirelessly just fine. I moved one satellite wireless to the other end of the house and it sync'd correctly. I moved the other satelli...
Nov 28, 2023Guru - Experienced User
replace the ends on the cable. A cable tester only says there's a connection. Not the quality of it. So it'll pass much easier versus having to pass data through it.
and you're talking 125 feet and not meters? Is that correct?
