DGlennon's avatar
DGlennon
Nighthawk R7000 - Doesn't reach far enough; do I need a more powerful router, or add an Access Point
Just bought a Nighthawk R7000 to improve my WIFI signal, but it didn't work.  Not a super long distance (about 35'), but apparently too many walls in between the router location and the laptop location.  Not a heavy user of devices--just looking for a super fast signal (my hardwired computer averages 100mbps).  Will upgrading to a more powerful router solve my issue, or should I install an Access Point?  I have a direct ethernet connection to most of the rooms in my home, so hard-wiring a second device would be pretty straightforward.  If an Access Point is the answer, and suggestions on specific products would be appreciated.  I know nothing about them.  Thanks!
  • All an Acess Point does, is extend your LAN. You're in a great position if you have ethernet throughout your home.. If you have the $$$, pick up an EX7000, configure as Access Point. Or if you have an old router lying around, configure it as an Access Point. The best would be something with external antennae's like the R7000.
    • DGlennon's avatar
      DGlennon
      Thanks for the info.  What would be the advantage of getting the EX7000 over something like the EX6100?  I currently have one computer and one phone which use the wifi (might find new uses in the future though!).
      • netwrks's avatar
        netwrks
        Master
        The EX7000 is an AC1900 class extender / Access point, as is your R7000. I'm not a big fan of those little plug in devices. Thie nice thing about the EX700 (or any router for that matter in AP mode) is that you can use the LAN ports to connect other devices into, as your network grows. I guess, ultimately, it all depends on the budget..
