oillogger's avatar
oillogger
Apprentice
Aug 27, 2018
Nighthawk r7000 AC1900 with MESH X6S XS8000 AC3000
I currently have a Nighthawk r7000 AC1900 router located in the far corner of my home and I am unable to move it closer to the center of my home for better Wi-Fi coverage.  I am considering purchasin...
  • StephenB's avatar
    Aug 28, 2018
    I have used the EX8000 - for eval some time ago, as my router system is an Orbi RBK50.
    The EX8000 has the same radio performance as the Orbi RBS50 (triband), so it should give good results for you.  If you use it in extender mode, you can dedicate one of the 5G radios for the EX8000->router connection (using fast lane), and use the second 5G radio for your devices.  That gives you the best performance in extender mode.  The main drawback (which applies to all extenders) is that you need to place the EX8000 where you can get a solid (preferably 5G) connection to the R7000 WiFi.
    If you can run ethernet to the EX8000, then you could also use it in AP mode, which eliminates any concerns about the quality/speed of the wifi backhaul.  If you do that, you'd also be able to use all three bands for your clients.
