Eagleswing
Jun 15, 2017Aspirant
Nighthawk r7000 Antennas- adjusting???
Just a question on the antennas on a Nighthawk Extender. Is there an ideal position for the antennas? Is straight up good, or at a 45 degree? Does pointing towards your router help? Thank you in...
DarrenM
Jun 21, 2017Sr. NETGEAR Moderator
Hello Eagleswing
Whatever is working best for your environment but typically them being vertical.
DarrenM
- EagleswingJun 22, 2017Aspirant
Thank you for your reply. Much appreciated!
