chad4ksu
Oct 01, 2016Follower
Nighthawk R7000 as Repeater
I am trying to set up my Nighthawk R7000 to use it as a repeater for my Comcast Xfinity Router. I have followed the instructions to turn off security and set channels. However, when I try to update...
TheEther
Oct 02, 2016Guru
My usual advice is to not bother trying to use a Netgear router as a repeater. As you have discovered, Wi-Fi security must be disabled, which means that anyone nearby can connect to your network.
Ok, maybe you are one of those folks who lives on a farm, so eavesdropping is not a concern. Well, the next problem is that Netgear routers uses an antiquated form of wireless repeating called WDS. Your Comcast router also needs to support WDS in order for the Netgear to connect.
You may want to consider installing AsusWrt-Merlin. It's 3rd party firmware and it should have a more modern implementation of wireless repeating that doesn't require any cooperation from the Comcast router.
