Sandraholt's avatar
May 14, 2020
Nighthawk R7000 won’t connect to internet
I couldn’t remember the password to my Nighthawk R7000 so I did a factory reset and after trying to get it to connect to the Internet for hours, I still can’t get it to connect. I called my Internet provider and everything is good on their end. I switched out the ethernet cable and the power cord with the new ones and that didn’t help. When I go to routerlogin.net, everything looks good except that I have a red bar on Internet connection that states that it is not connected. I am about to pull out my hair over this issue! If there are any ideas out there, please let me know.
  • I also connected directly to the router with an ethernet connection and I’m getting nothing. No Internet.
  • plemans's avatar
    what modem are you connecting to?
    Firmware on the router?
    • Sandraholt's avatar
      Sandraholt
      Tutor
      The problem mysteriously just resolved itself after working on it ALL DAY... Thanks for offering to help.
