jmotes
Dec 08, 2021Guide
Nighthawk R7350 and AX8 combined onto one network issues
I have a nighthawk R7350 in my house running my network and I purchased an AX8 a while ago and wanted it to continue to share on the same wifi network so I could travel from my house to my shop witho...
Dec 08, 2021Guru - Experienced User
Have you tried turning down the broadcast power on the R7350?
you can set the ssid broadcast power so it doesn't reach as far.
neither router is a mesh system so they don't "integrate" but if the power is lower enough the R7350 disconnects, it should auto-connect to the AX8
jmotes
Dec 08, 2021Guide
Bummer, ok well i guess i am looking for new stuff. I thought when i bought the ax8 that was an option.
