ellisonwTX
Oct 02, 2020Follower
Nighthawk R8000 Wired Connection Slower than ATT modem
I thought my issues were with my AT&T modem, so they swapped it out yesterday. When the computer is wired into the new modem I get 840Mbs. If I plug my computer into my router, and the router into th...
Oct 02, 2020Guru - Experienced User
What att modem are you using?
Is the att device in passthrough/modem only mode? Or the netgear in access point mode?
make sure that access control, traffic monitoring, qos, and parental controls are all disabled.
I'd even recommend a full factory reset and manual reinstall if they ever were enabled. Reason why is I've read of settings being retained even through the services were disabled.
