krick1
Jan 01, 2024Aspirant
Nighthawk Range Extender App
I got the 1600 model range extender and couldn't even set it up. The app refused to connect/log the extender into the 5.2gHz band of my Bell Home Hub 300 router. Tried multiple times and repeatedly s...
Jan 02, 2024Guru - Experienced User
Not clue what model extender you have as you didn't give a model number.
You can try using the WPS method of setup.
or you can set it up using the installation assistant.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
if you need to, To factory reset, push and hold the reset button for 7-15 seconds while powered on.
