Bkhamer
Dec 31, 2024Aspirant
Nighthawk RAX54v2
Hi! I have a modem and nighthawk router that was connected. Had to unplug for months. Couldn’t get it to reconnect so stated completely over. I have rebooted the modem and the nighthawk. Problem is t...
Jan 01, 2025Guru - Experienced User
You factory reset it?
If so, the wifi password should be on the device.
Are you using the app for setup or logging in and using the GUI for setup?
- BkhamerJan 01, 2025AspirantUsing the app. Can’t get to the admin page to log into admin and password. Only have the 5g account that shows up.
Also tried the 30/30/30 factory reset and it won’t reset. Do I just need to buy a new one?- plemansJan 01, 2025Guru - Experienced User
no. Just hardwire a pc/laptop/tablet into the router and log into to access it
Or look at the label. The ssid password should be the same for 2.4 and 5ghz
