Bkhamer
Dec 31, 2024Aspirant
Nighthawk RAX54v2
Hi! I have a modem and nighthawk router that was connected. Had to unplug for months. Couldn’t get it to reconnect so stated completely over. I have rebooted the modem and the nighthawk. Problem is t...
Jan 01, 2025Guru - Experienced User
You factory reset it?
If so, the wifi password should be on the device.
Are you using the app for setup or logging in and using the GUI for setup?
Bkhamer
Jan 01, 2025Aspirant
Using the app. Can’t get to the admin page to log into admin and password. Only have the 5g account that shows up.
Also tried the 30/30/30 factory reset and it won’t reset. Do I just need to buy a new one?
