wayne1960
Apr 11, 2020Aspirant
Nighthawk Roaming
Hi reluctantly i have had to ask the audiance lol. i have my new Nighthawk set up and all lights on and connection appears to be solid. i have a good internet service via my Virgin Hub 3. When i log...
Apr 11, 2020Guru - Experienced User
Did you set it up via wps? If so, try the installation wizard.
What actual router did you connect to? not all ISP supplied routers play well with extenders
What firmware is on the extender?
- wayne1960Apr 11, 2020Aspirant
Did you set it up via wps? Yes and it seems to have set up ok as i get all white lights and all green on the extenders browser
If so, try the installation wizard, Not sure if its going to be any better.
What firmware is on the extender. V1.0.1.206
As i said it all appears to be set up properly but internet is a no go and it doesnt roam which was one of the benefits i wanted.
Sorry the router is my Virgin Hub 3
- plemansApr 12, 2020Guru - Experienced User
wayne1960 wrote:Did you set it up via wps? Yes and it seems to have set up ok as i get all white lights and all green on the extenders browser
wps can be coded differently by different manufacturers. the virgin hub 3 is one of those. Try the installation wizard and not wps.
- wayne1960Apr 15, 2020Aspirant
Ok i have done everything suggested and its simply not working well.
Everything appears to be all good and i gat all indicators lighting as they should and when i log into the extender it says that all signals are green
But and there is always a but. When i roam or try to get internet on my phone or i pad i gat nothing.
If i turn off WiFi and reconnect boom it works and then it goes again the next time i try.
Please help.
