kbelbert
Dec 24, 2020Aspirant
nighthawk router R7000 and using extenders
Installed this router a month ago to replace an old netgear router as our internet company suggested our old router wasnt powerful enough. I dont see any difference in speed, but most frustrating, is...
Dec 24, 2020Guru - Experienced User
What modem do you have?
What firmware is on the R7000?
What extender do you have?
Are you streaming over 2.4ghz or 5ghz?
- kbelbertDec 24, 2020Aspirant
Spectrum supplied the modem : E31T2V1
No idea what firmware is on the router--I am very tech challenged--where would I find that on the device?
Extender: WN3000RPv3
Not sure which we are streaming on, 2.4 oe 5G. Since our TV is 7 years old, is it possible it doesnt have 5G capacity?
- plemansDec 24, 2020Guru - Experienced User
kbelbert wrote:Spectrum supplied the modem : E31T2V1
No idea what firmware is on the router--I am very tech challenged--where would I find that on the device?----on the status page if you log in through the browser.
Extender: WN3000RPv3----pretty much a base model 2.4ghz extender. I wouldn't use it for HD streaming.
Not sure which we are streaming on, 2.4 oe 5G. Since our TV is 7 years old, is it possible it doesnt have 5G capacity?---anythings possible. but if you have a model number, we can look it up. Just make sure if you're streaming to have the tv connected to 5ghz. 2.4ghz is much much slower and sensitive to interference. this can cause issues.
firmware V1.0.9.88_10.2.88
What extender would you suggest?
Samsung LED TV Model 7100
there's different versions of the samsung 7100. Which one do you have?
In terms of extenders, I'm a fan of the tri-band line. They don't drop speeds nearly as much as the dual band versions.
the r7000 isn't known for great firmwares.
What I'd try first is upgrade to the latest version 1.0.11.110. do it over a hardwired connection, then factory reset after the firmware upgrade, and then do a clean install (not using a backup configuration)
If that doesn't help, try version 1.0.9.42 of the firmware. Its the agreed upon most stable version of the firmware. again install over ethernet, reset, and clean install.
