Swindonpete
Nov 29, 2020Guide
Nighthawk Wi-Fi extender and Ring camera live view
Hi I have a Ring camera and a Nighthawk extender but I can't get a live view on my Ring app although the Ring app shows the camera as connected with RSSI c-55 and the motion sensor lights trigger on ...
Swindonpete
Nov 29, 2020Guide
Thanks for the quick reply. I will have a look at a couple of your points in the morning here (UK) and answer the others too. Thank you again. I’ll get back to you tomorrow.
Swindonpete
Nov 30, 2020Guide
Hi again,
No other ring devices have any problems but are connected to my BT router. The camera in the garden got v poor signal and would not work so I bought the Netgear. I set it up not using WPS as advised by others when I looked into it. I connected my camera via Wi-Fi (which I brought into the house) to my BT router this morning and live view works fine but it didn't when connected to the netgear? Is there a setting on th emerge are I need to change or? Thanks again for your help with this issue.
