Swindonpete
Nov 29, 2020Guide
Nighthawk Wi-Fi extender and Ring camera live view
Hi I have a Ring camera and a Nighthawk extender but I can't get a live view on my Ring app although the Ring app shows the camera as connected with RSSI c-55 and the motion sensor lights trigger on ...
Swindonpete
Nov 30, 2020Guide
Hi again,
No other ring devices have any problems but are connected to my BT router. The camera in the garden got v poor signal and would not work so I bought the Netgear. I set it up not using WPS as advised by others when I looked into it. I connected my camera via Wi-Fi (which I brought into the house) to my BT router this morning and live view works fine but it didn't when connected to the netgear? Is there a setting on th emerge are I need to change or? Thanks again for your help with this issue.
Nov 30, 2020Guru - Experienced User
There's not a lot for changes to be made with it.
What firmware version is on it?
during setup, did you click on the "extend 2.4ghz broadcast"? I'll attach what I mean.
I usually don't use that so the extender only uses the 5ghz backhaul. This also lets you change the 2.4ghz channel the extender uses. maybe the one you're on has interference.
So potentially rerun setup on the extender and leave the "extend 2.4ghz" unchecked. Again, it'll still use it, it just won't use it as a backhaul.
- SwindonpeteNov 30, 2020GuideHi
Thanks for this. The firmware version shows as V1.0.0.210
The Ring only uses 2.4 I think? I did not enable the 5ghz channel. I did not see a “extend 2.4ghz” box to click? Does this I don’t understand what “backhaul” means (I’m sorry for my lack of experience) What should I do next do you think? Thanks again.- plemansNov 30, 2020Guru - Experienced User
Swindonpete wrote:
Hi
Thanks for this. The firmware version shows as V1.0.0.210----Not the greatest version. I'd downgrade it to version 1.0.0.206. We've seen a few issues on the newer .210 version.
The Ring only uses 2.4 I think? I did not enable the 5ghz channel. I did not see a “extend 2.4ghz” box to click?----You'd see it during setup. I re-ran the setup on my EX8000 to show you what you'd see during setup. Does this I don’t understand what “backhaul” means (I’m sorry for my lack of experience)----The triband line of extenders have 2x 5ghz channels. 1 of those is just for backaul. What that means is its only used for a connection back to the router. And then the other 5ghz is just for devices to connect to. This allows faster communication and lower latencies than devices that have to go router---extender---device on a single band. What should I do next do you think? Thanks again.What I'd start with? downgrade the firwmare on it to the .206 version mentioned above and see how it works. If it works fine, awesome. If it doesn't, then I'd factory reset the extender and reinstall it. During the install, uncheck that 'enable 2.4ghz" connection. Again, you'll still be able to use 2.4ghz but it'll use the dedicated backhaul
- SwindonpeteDec 01, 2020Guide
Thanks for your very helpful advice. I've managed to do as you,have suggested and, as the moment, it's working - thank you. The "proof of the pudding" will be in c 48 hours time as when I first installed it worked too, but I'm very grateful for your help and quick responses to my plea for help. I'll update in a couple of days time for your information etc. Thanks again.
