jd49
Jan 31, 2019Aspirant
Nighthawk X4 AC2200 EX7300 not working failed update
Nighthawk X4 AC2200 EX7300.
I made a mistake downloading a firware update. I downloaded it thru another network instead of the extender network. I went thru all the process to download the update, ...
- Feb 01, 2019
Problem Solved.
I Kept searching in google and found an article that solved the problem. Hope it helps you too. Follow carefully the instructions. Make sure first that your Windows has the TFTP option ON (How to: https://www.howtogeek.com/250228/what-windows-10s-optional-features-do-and-how-to-turn-them-on-or-off/ ).
How to install the firmware via TFTP to try and recover the device: https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
Download the Firmware here: https://www.netgear.com/support/product/ex7300.aspx#Firmware%20Version%201.0.2.140
Hope it helps.
KeeleyC
Feb 01, 2019Aspirant
I have exactly the same problem! - Netgear can you please respond?
- jd49Feb 01, 2019Aspirant
Problem Solved.
Hope it helps.
