WROC
Jan 17, 2021Tutor
Nighthawk X4 AC2200 Extender Model EX7300 has not created 2 new extender WiFi networks.
Help Please, I've just purchased the above and have set up the extender using WPS no problems. Have solid green lights for Router and Client Link also green lights for power and WPS. My understandi...
- Jan 18, 2021
They'd actually need 2 guides because mesh wasn't added until version 1.0.2.136 with the ex7300. so it was technically correct for older versions of the firmware. :)
so you're are correct that the guide doesn't help and can cause confusion if you're on the newer firmware.
WROC
Jan 18, 2021Tutor
Sorry about that - I'm a new community member.
michaelkenward
Jan 18, 2021Guru - Experienced User
No problem. I didn't want you to waste time wading through mountains of irrelevant junk.
