Schizy86
Oct 22, 2021Follower
Nighthawk X4 Questions
Hello Community! I set up my wifi extender and I have some questions on this as I searched online and couldn't find the answers or possible solutions to my questions. 1. I share a household...
Oct 22, 2021Guru - Experienced User
Schizy86 wrote:
1. I share a household with buddies and they soak up a lot of usage, my purpose for the extender too was because I wasn't in the best spot. Is there a way to set this up securely so that I can put a password on the extender so that others aren't able to connect? If so, how? ---Yes you can. If you set it up using the installtion assistant, you can choose to change the ssid and password for it. That means only you can access it. If you set it up using the wps method or using the one wifi option, then it uses the same ssid/password as the router. So simply factory reset it (push and hold reset for 7-15 seconds while powered on), then during setup, using the installation assistant method. There'll be a step during setup where you either choose to use the same ssid or change it. Simply change it.
2. Are you able to take devices from connecting to it if there are multiple? If so, how?---I have no idea what you're trying to say or achieve here. A little more detail would help.
I appreciate all support!
Thanks!
