genes161
Mar 21, 2020Aspirant
Nighthawk X4 R7500 AC2350 Smart WiFi Route
I have the speed 250/100. Can you get that speed (250) out of the lan with r7500 nighthawk? As it is now I only get 100/100 on the lan.
Mar 21, 2020Guru - Experienced User
what modem is it connected to?
have you checked your cable? make sure to have a cat5e or > cable.
firmware on your router?
are you using qos? if so disable it and reboot.
what device are you testing speed on? is it gigabit capable? make sure you're testing over hardwired connection to.
- genes161Mar 29, 2020Aspirant
This is what it looks like.
Cables are checked, Qos is unselected and latest firmware.
How do I get full speed (250) on lan1 and 2?
- plemansMar 29, 2020Guru - Experienced User
genes161 wrote:This is what it looks like.
Cables are checked, -----did you try replacing them? Qos is unselected and latest firmware.
How do I get full speed (250) on lan1 and 2?-----connect them to a gigabit device? With connections capable of gigabit? not all devices are gigabit.
https://imgur.com/gallery/vdd7Pa0
Its connected to my pc, ethernet connection (2)I219-V. and its capable of 1gigabit.
