rivancic's avatar
rivancic
Follower
Mar 27, 2019
Nighthawk x4S EX7500 booting forever
I purchased brand new expensive repeater. Plug it in the power outlet set it up. I used it for one week. Came home after I plugged it in the socket its booting forever. Blue light blinking. I tried to turnit it off. Without success. I wanted to restart. Reboot nothing. I keep pressed rebot button for 5 seconds 30 seconds, 1 minute nothing. Its stil power led blinking and blinking. I can not believe that I paid a fortune for the device that is stable for a week. What can I do mext?
1 Reply
  • plemans's avatar
    Blinking blue on the power light means its resetting to default settings. You might have interupted that by turning it off. You stated " wanted to restart. Reboot nothing. I keep pressed rebot button for 5 seconds 30 seconds, 1 minute nothing. Its stil power led blinking and blinking"
    I'm not positive you were using a pin to hold in the factory reset button on the side. Use a pin to hold that button in for around 5-10 seconds. It should factory reset the device. Let it boot for a couple minutes. See if that resolves it.
