ChrisvT
Apr 17, 2020Follower
Nighthawk X4S model EX7500
Have installed the NH X4S, EX7500 and got everything to operate well (5GHz). However after approx 24hrs the blue 5GHz light goes OFF while the blue router light remains nicely ON. Any suggestion wh...
Apr 17, 2020Guru - Experienced User
You might not be doing anything "wrong".
The EX7500 is a mesh router with band steering. Band steering moves devices from band to band as needed based on some magical formula of rssi/distance/bandwidth.
Potentially your device could be being "steered" to the 2.4ghz signal as its not needing the full speed of 5ghz.
that's what the led is showing is nothing connected. Not that its off.
You can log into the extender and see what devices are connected to which channel. As well as if 2.4ghz/5ghz is broadcasting.
