Kay01
Jul 09, 2020Aspirant
Nighthawk x4s
Extender was working great for 8 months but now no longer working. Only light on is power. I have reset but still nothing. Can't recognize router now which is a cisco. I have not changed any settings...
Jul 09, 2020Guru - Experienced User
Are you trying to reinstall it using the wps method of install or using the smart installation wizard?
I'd highly recommend setting it up via the installation wizard when you're using a router from a different manufacturer.
Kay01
Can't locate the smart wizard. Do you have a link. I did the guided assistance but still can't connect.
- plemansJul 09, 2020Guru - Experienced User
The support site has an install video. I think its the 2nd video if you click the over button. About 2 minutes in, it shows the installation wizard being used.
https://www.netgear.com/support/product/EX7500.aspx
- Kay01Jul 09, 2020Aspirant
Thanks. I found it and was able to get the wifi light to go on but still nothing. I liked this product but this is too time consuming. It will be returned.
- plemansJul 10, 2020Guru - Experienced User
You also have the option of contacting support for free if you're within your free 90 days of support (from date of purchase)
Simply click mynetgear at the top, register an account, and then the device. From there you can contact support.
