Kay01
Jul 09, 2020Aspirant
Nighthawk x4s
Extender was working great for 8 months but now no longer working. Only light on is power. I have reset but still nothing. Can't recognize router now which is a cisco. I have not changed any settings...
Kay01
Can't locate the smart wizard. Do you have a link. I did the guided assistance but still can't connect.
Jul 09, 2020Guru - Experienced User
The support site has an install video. I think its the 2nd video if you click the over button. About 2 minutes in, it shows the installation wizard being used.
https://www.netgear.com/support/product/EX7500.aspx
- Kay01Jul 09, 2020Aspirant
Thanks. I found it and was able to get the wifi light to go on but still nothing. I liked this product but this is too time consuming. It will be returned.
- plemansJul 10, 2020Guru - Experienced User
You also have the option of contacting support for free if you're within your free 90 days of support (from date of purchase)
Simply click mynetgear at the top, register an account, and then the device. From there you can contact support.
- Kay01Jul 11, 2020Aspirant
Thank you, Yes I did call support but since it's not within the 90 days I need to pay $90 for someone to help. If it in fact is a defected extender they will not do anything since it's not within the 90 days. So seems like I should put the $90 towards a new extender. Thought I should have gotten more than a year out of this product.
