Gregc49
Dec 10, 2020Aspirant
Nighthawk X6 AC2200 EX7700 Drops connection to connected devices.
Cannot maintain connection with mobile phones, both Apple and Android. Will drop in and out, with the Android says "Incorrect Password" when trying to log in to the network. The Apple just stays disc...
- Dec 18, 2020
If you do run into issues, try the downgrade.
Its pretty easy. You simply follow the manual update process from the manual and use the older firmware.
Dec 12, 2020Guru - Experienced User
what telstra device is it?
Have you tried changing the router---extender link channel to the higher bands?
or moving the extender around a little? the 5ghz band doesn't broadcast as far or through as much materials. So sometimes a lateral move can help in removing obstructions that could be blocking the signal.
Gregc49
Dec 15, 2020Aspirant
It is a Telstra Smart Modem Gen 2.
I am trying a different position, still assessing performance but still some problems.
Thinking of changing the extender to its own unique SSID, see if the phone and tablet may be having difficulty discriminating between router and extender. In a remote room where the extender is the dominant signal all seems to work ok.
Stay tuned.
- plemansDec 16, 2020Guru - Experienced User
Are you on version 1.0.0.210 of the firmware?
If so, downgrade tot he 1.0.0.206 version, factory reset, and reinstall. After reinstall, disable auto-updates. I've seen a coupe posts where people are having issues on the latest firmware.
- Gregc49Dec 17, 2020Aspirant
Hi,
I have the 210 version of software. I did the restart as suggested but it goes direct to the latest software. Can't see how one can change back to the 206 version.
The extender is in a better location now and I have set it to use it's own SSID. It is closer to the area I want to serve and both devices now work happily. The mobiles connect direct to the router through the main part of the house so all is well.
So, don'y understand why the shared SSID didn't work well but all looks good now. Thanks for your help.
- plemansDec 18, 2020Guru - Experienced User
