Gregc49's avatar
Gregc49
Nighthawk X6 AC2200 EX7700 Drops connection to connected devices.
Cannot maintain connection with mobile phones, both Apple and Android. Will drop in and out, with the Android says "Incorrect Password" when trying to log in to the network. The Apple just stays disc...
  • plemans's avatar
    Dec 18, 2020
    If you do run into issues, try the downgrade.
    Its pretty easy. You simply follow the manual update process from the manual and use the older firmware.
