Sky23
Apr 10, 2021Aspirant
Nighthawk X6 AC2200 no longer broadcasts
Hello. My three-year-old AC2200 no longer broadcasts, my fault for knocking it off my desk. Bose and Apple have trade-in policies for defunct products, giving you some credit to encourage you to ...
Sky23
Thanks very much for your message.
Do the led lights come on for it?
Yes, although every button except for the double arrows is now faint.
Did the on/off button get hit? (both for power and wifi on/off)
The on/off button is on; the unit has throughput but no WiFi signal
The wifi on/off button needs to be pushed for 2 seconds .
There are only two buttons on the X6: a WPS button (which is for an automated connect) and the on-off button. There is no physical WiFi button.
Apr 11, 2021Guru - Experienced User
Its does have a wifi on/off button.
Not sure what router you have as AC2200 is a speed and not a model.
But go to netgear.com/support/
type in its actual model number.
it'll take you to the support site with manuals. the manual goes over which led is the wifi on/off button. push and hold it for 2 seconds.
