TimNiceBut
Mar 30, 2020Guide
Nighthawk X6 AC2200 questions
I bought this Nighthawk X6 Tri-Band WiFi Mesh Extender to get a stronger wifi signal throughout the house and into the back garden. I bought it to replace a TP-Link RE360 range extender but either I'...
TimNiceBut
Mar 30, 2020Guide
Well I'm guessing that I did have mesh running, as the extender has the same two SSIDs as the router and my iPhone switched between the two (5G network on each) without me doing anything other than moving around between the front of the house router) and the back (extender).
TimNiceBut
Apr 03, 2020Guide
And it's gone quiet. I guess I'll be returning this then....
- plemansApr 03, 2020Guru - Experienced User
I guess I misunderstand what you're asking then because your last response didn't have any questions.
And this is the community forum. where members of the public are helping others out. We're not netgear. threatening to return a product only impacts who I help by making me less likely to help someone.
- TimNiceButApr 04, 2020Guide
I've no idea as to your level of understanding. I asked if I had the right piece of kit or whether I was doing someting extremely dumb, given that my cable tv box or Ring camera wouldn't connect to the X6 in the same room but both would connect to my TP Link RE360 two rooms away.
Your response was to ask me about the Mesh, which I answered. It then went quiet.
I understand that this is a community forum and the potential return of the X6 wasn't a threat; it was an observation. I was hoping for more help but thus far have received nothing of value.
Toodle pip.
- DexterJBApr 07, 2020NETGEAR Moderator
Hi TimNiceBut, just to isolate, try turning off the main router (or just the wireless radio if possible) then check if the device that you intend to connect to the extender does connect to it.
Dexter
