Sarah_louise
Sep 06, 2023Aspirant
Nighthawk X6 extender question - can you use two?
Hi, I’m using a Nighthawk X6 extender to extend the wifi in my house, but I need to extend it further. My router is at one end of the house and then the current extender is in the middle of the house...
Sarah_louise
Sep 07, 2023Aspirant
Thanks very much for your advice. I don’t think I can move the router though. It has to be plugged in to the broadband socket, which is in a specific room at the end of the house
Sep 09, 2023Guru - Experienced User
You can daisy chain them but if you run into stability issues, take disable one of the extenders "one wifi" feature and change its ssid so its different. Helps prevent them from connecting to each other
