Sarah_louise
Sep 06, 2023Aspirant
Nighthawk X6 extender question - can you use two?
Hi, I’m using a Nighthawk X6 extender to extend the wifi in my house, but I need to extend it further. My router is at one end of the house and then the current extender is in the middle of the house...
Sarah_louise
Sep 07, 2023Aspirant
Thanks very much for your advice. I don’t think I can move the router though. It has to be plugged in to the broadband socket, which is in a specific room at the end of the house
Retired_Member
Dec 06, 2023Sarah_louise Do you have broadband port in more than one room in the house?
When we bought our house, the modem had been connected in the Kitchen on the main floor. I had a connection in the bedroom on the second floor. So I put my modem and router up there, so wifi started out on the second floor for better coverage. Feel free to check if you can connect your modem in more than one room in your home for better coverage.
