Detritus2uk
Aug 08, 2023Aspirant
NightHawk X6S AC3000 EX8000 - All LEDS on front flashing .
NightHawk X6S AC3000 EX8000 - All LEDS on front flashing . Wired connections work but wifi does not. Have tried factory reset (rest 7 seconds) but not change. Can anybody advise. Is there are hard re...
Aug 09, 2023Guru - Experienced User
But the wired connections to it work fine?
Have you tried going through the setup while hardwired into it?
- Detritus2ukAug 09, 2023Aspirant
The wired connections can talk to each other but and the internet provided one of the connections is a wired connection to the router but the management website will not connect and the AP does not show as connected or get an IP address .
