Detritus2uk
Aug 08, 2023Aspirant
NightHawk X6S AC3000 EX8000 - All LEDS on front flashing .
NightHawk X6S AC3000 EX8000 - All LEDS on front flashing . Wired connections work but wifi does not. Have tried factory reset (rest 7 seconds) but not change. Can anybody advise. Is there are hard re...
Aug 09, 2023Guru - Experienced User
But the wired connections to it work fine?
Have you tried going through the setup while hardwired into it?
Detritus2uk
Aug 09, 2023Aspirant
The wired connections can talk to each other but and the internet provided one of the connections is a wired connection to the router but the management website will not connect and the AP does not show as connected or get an IP address .
