will294
Sep 28, 2017Initiate
Nighthawk X6S AC3000 Tri-Band WiFi Range Extender (EX8000) Firmware update question?
Hi, Do you know if there will be a Firmware update to support WPA2 in the 5Ghz band? Cause for now i have to disable the 5Ghz band because the extender leave my 5Ghz band without password instea...
DarrenM
Sep 29, 2017Sr. NETGEAR Moderator
- When EX8000 cannot connect to Telus ActionTec 3200M router with WPA2 security setting via 5G, can EX8000 connect to router with same security setting via 2.4G connection?
- Can other clients can connect to 3200M router with same WPA2 security setting via 5G?
- Can you connect to any other security type on the 5g?
- re-check 5G channel setting of 3200M router is not FCC DFS channel. Present EX8000 does not support FCC DFS channel.
DarrenM
- will294Sep 29, 2017InitiateHi guys, thanks a lot for your help. It finaly worked! I used the Smart Setup instead of using the WPS connect, and that way the extender saw the 5ghz password and connect to it.
Have a nice day!
Thanks again!
