Jbid9020
Aug 02, 2024Aspirant
Nighthawk X6s AC3000 will not connect to router
Hi, After a brief power outage the above extender has stopped connecting to router. I have tried rebooting both (in close proximity to one another), with the same result. One thing has changed I have...
- Aug 07, 2024
factory reset the extender and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
Aug 02, 2024Guru - Experienced User
Power surges are great at corrupting settings.
I'd try a factory reset and reinstall of the device.
- Jbid9020Aug 02, 2024AspirantThanks, tried this the same result.
- plemansAug 02, 2024Guru - Experienced User
when you factory reset and then connect to the netgear_ext and go through setup, what happens?
It doesn't work doesn't tell us much. Does it go through setup?
Are you unable to access it?
If you log into the router, does the extender show as an attached device?
Can you access it through its IP address the router assigns to it?
- Jbid9020Aug 03, 2024Aspirant
Thanks,
I am what they used to call a 'silver surfer', (you could add 'very' to this) so my knowledge of the finer workings of computer technology is limited.
The power outage was planned so unlikely to have been a surge as I switched everything off and then powered back up after, poor explanation on my part. Since then I have turned the router off a number of times as that seems to be the go to advice, for quick fixes.
I Uninstalled the Nighthawk app and reinstalled in case that might be a quirk.
I reset the the extender and placed it next to the router.
I then tried to setup the device again, my phone is connected to my router address. The app then tells me that I am not connected to the internet, and gives me a suggestion to connect to NETGEAR EXT. When I do this the app try's to detect the product but goes no further.
No, although not sure what it is, I assume the extender.
Yes, I assume you mean the scan is seeing NETGEAR EXT as a network
I'm not sure what or how to do this .
Cheers
John
