Jbid9020
Aug 02, 2024Aspirant
Nighthawk X6s AC3000 will not connect to router
Hi, After a brief power outage the above extender has stopped connecting to router. I have tried rebooting both (in close proximity to one another), with the same result. One thing has changed I have...
- Aug 07, 2024
factory reset the extender and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
Jbid9020
Aug 03, 2024Aspirant
Thanks,
I am what they used to call a 'silver surfer', (you could add 'very' to this) so my knowledge of the finer workings of computer technology is limited.
The power outage was planned so unlikely to have been a surge as I switched everything off and then powered back up after, poor explanation on my part. Since then I have turned the router off a number of times as that seems to be the go to advice, for quick fixes.
I Uninstalled the Nighthawk app and reinstalled in case that might be a quirk.
I reset the the extender and placed it next to the router.
Does it go through setup?
I then tried to setup the device again, my phone is connected to my router address. The app then tells me that I am not connected to the internet, and gives me a suggestion to connect to NETGEAR EXT. When I do this the app try's to detect the product but goes no further.
Are you unable to access it?
No, although not sure what it is, I assume the extender.
If you log into the router, does the extender show as an attached device?
Yes, I assume you mean the scan is seeing NETGEAR EXT as a network
Can you access it through its IP address the router assigns to it?
I'm not sure what or how to do this .
Cheers
John
Aug 05, 2024Guru - Experienced User
I then tried to setup the device again, my phone is connected to my router address. The app then tells me that I am not connected to the internet, and gives me a suggestion to connect to NETGEAR EXT. When I do this the app try's to detect the product but goes no further.----Try doing it using the web browser and not the app.
No, although not sure what it is, I assume the extender.----I mean access it via the browser
Yes, I assume you mean the scan is seeing NETGEAR EXT as a network---that'd be the SSID (Name broadcasting). Not what we're talking about. If you log into your router, the extender should show up as an attached devices if its been setup.
I'm not sure what or how to do this .----see above
Cheers
John
- Jbid9020Aug 07, 2024Aspirant
Thanks for your patience,
I cannot access it through the web browser, and it is not listed in my routers connected devices.
Regards
John
- plemansAug 07, 2024Guru - Experienced User
https://www.youtube.com/watch?v=yJVklshxBMk- Jbid9020Aug 08, 2024Aspirant
Thanks
I paired the WPS, and it started working, logs in with nighthawk app and seems to be working ok now thanks.
The nighthawk extender doesn't show on the routers connected devices though, which seems strange.
Thanks again for your help.
Regards
John
