Jbid9020
Aug 02, 2024Aspirant
Nighthawk X6s AC3000 will not connect to router
Hi, After a brief power outage the above extender has stopped connecting to router. I have tried rebooting both (in close proximity to one another), with the same result. One thing has changed I have...
- Aug 07, 2024
factory reset the extender and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
Aug 05, 2024Guru - Experienced User
Does it go through setup?
I then tried to setup the device again, my phone is connected to my router address. The app then tells me that I am not connected to the internet, and gives me a suggestion to connect to NETGEAR EXT. When I do this the app try's to detect the product but goes no further.----Try doing it using the web browser and not the app.
Are you unable to access it?
No, although not sure what it is, I assume the extender.----I mean access it via the browser
If you log into the router, does the extender show as an attached device?
Yes, I assume you mean the scan is seeing NETGEAR EXT as a network---that'd be the SSID (Name broadcasting). Not what we're talking about. If you log into your router, the extender should show up as an attached devices if its been setup.
Can you access it through its IP address the router assigns to it?
I'm not sure what or how to do this .----see above
Cheers
John
Jbid9020
Aug 07, 2024Aspirant
Thanks for your patience,
I cannot access it through the web browser, and it is not listed in my routers connected devices.
Regards
John
