Jbid9020
Aug 02, 2024Aspirant
Nighthawk X6s AC3000 will not connect to router
Hi, After a brief power outage the above extender has stopped connecting to router. I have tried rebooting both (in close proximity to one another), with the same result. One thing has changed I have...
- Aug 07, 2024
factory reset the extender and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
Aug 07, 2024Guru - Experienced User
Jbid9020
Aug 08, 2024Aspirant
Thanks
I paired the WPS, and it started working, logs in with nighthawk app and seems to be working ok now thanks.
The nighthawk extender doesn't show on the routers connected devices though, which seems strange.
Thanks again for your help.
Regards
John
