mwwilson
Jul 27, 2020Aspirant
Nighthawk X6S All lights blink white on front and power lite in back blinks red
Machine had been working fine for 6 months. All of a sudden all the front lights were blinking white and the power light was blinking red. Tried to reset without success. when unplugging and replugin...
Jul 27, 2020Guru - Experienced User
usually when the powerline is amber its not a good sign. You might be a canadite for a tftp recovery if factory resetting doesn't work.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
mwwilson
Is red and amber the same on this machine?
