Cirruz's avatar
Cirruz
Nighthawk X6S (X8000) Extender - where are Ethernet ports internally connected to?
Hello!
I am using my X6S to extend two WiFi networks: a 2.4GHz network that I only use for IoT devices, and a 5GHz network that I use for regular Internet access.
On my router, the IoT and general access networks are linked to two different VLANs.
If I connect something to one of the extender's Ethernet ports, to which internal WiFi repeater is it connecting that to? The documentation doesn't say anything and the configuration is very limited.
Thank you!
  • plemans's avatar
    good questions. I'm not at home right now (and won't be for a bit) to connect me EAX80 and try it.
    There used to be an option you could select which band the ethernet ran through. Not sure if that setting is still there though
    • Cirruz's avatar
      Cirruz
      Thank you! I ended up moving the device from the extender to the router, because I couldn't make it work there. I couldn't find any settings, besides changing the SSIDs and secrets, there's nothing much else that can be changed.
