Lhudson2
Jul 09, 2020Follower
Nighthawk X6S
Can I install my extended laying on its back or side?
Jul 10, 2020Guru - Experienced User
Can you install it that way? Sure
Will it potentially reduce the lifespan of it? Probably. Its designed with a certain orientation to passively cool it. If you're laying it down/putting it on its side, its potentially impacting how it cools. heat is the death of electronics.
But it might never impact it or cause an issue.
For example, I have a RAX200 thats not designed to be wall mounted. But it is. And I've had it over a year with it running normally and the fan never kicking on.
So its kind of up to you if its worth the risk of a shorter lifespan or not.
Or if you've got a fan/cooler to direct at it, it might not change it at all.
