JE30
Dec 29, 2020Follower
Nighthawk X6S
So I purchased a netgear Nighthawk X6S Tri-Band WiFI Mesh Extender. It's been a couple of months since I had set it up. I tried speaking to technical support since I have forgotten my login and passw...
Dec 30, 2020Guru - Experienced User
support doesn't have your login/password.
there's a password recovery option. but it requires that you set it up during setup as well as that you remember the security questions.
If you don't know the answers or didn't set it up, then you'd need to factory reset to get back in.
