EamusCatuli
May 20, 2021Aspirant
Nighthawk XR1000 and Mesh Help
I have a NETGEAR Nighthawk Pro Gaming 6-Stream WiFi 6 Router (XR1000) - AX5400 in my current home of 1500 sq ft and works fine. It's all wood and drywall and compact so I still get decent speeds in...
May 21, 2021Guru - Experienced User
you can use mesh extenders but I usually advise people to avoid them and go with a full mesh system if they think they're needing more than 1 extender.
how many do you need? Depends. Each home is different. the nice thing about mesh system is you can add satellites pretty easily.
The XR1000 isn't a mesh router. so it doesn't integrate with mesh systems.
If you're wanting to retain the gaming features of hte xr1000 but have a mesh system, you can always add a mesh system like orbi to it and run the orbi in access point mode.
then you retain the benefits of the DumaOS while still having the coverage of orbi.
EamusCatuli
May 21, 2021Aspirant
Thank you!! I appreciate the info!! Very helpful!!
