yong20
May 24, 2020Follower
Nigthawk MR60 / MR63 Missing Parental Controls
I used to use circle for parental control for my old netgear wifi router. Recently switched to MR60 Mesh but couldn't find any parental control features. Is parental control on the feature roa...
DP10
Aug 02, 2020Initiate
I was told by Netgear technical support the reason the router doesn't have parental controls is because the router is too new. They said since the router is only 2 months old the engineers haven't had time to get it supported for parental controls. They do have plans to offer parental controls through CIRCLE, but it is not available yet. Parental Controls is part of the reason I bought a Netgear Nighthawk Router.
- ekuhnSep 04, 2020Initiate
Any addiontional word on this. Hard to belive they dont have basic time limits and bedtimes on the this set-up. Even my terrible (former) comcast modem/router had this ability.
- KhalidsamirSep 05, 2020Initiate
After school had started, i had to go back to the Xfinity modem.
