Redman1970
Apr 15, 2019Aspirant
No Blinking green light on Netgear powerline1200
I installed my Netgear Powerline 1200 today. I have all 3 green lights on solid on both adapters, but the quick start guide says that the “pick a plug” green light should be blinding to indicate tha...
- Apr 16, 2019
If the lights are solid green, they're linked and communicating correctly. Once this is up and running you push the security button and the 1st device. Once the light is blinking, you have to push the security button on the 2nd device within 2 minutes. If you don't, you'll need to do a reset on both devices and start over again.
Apr 16, 2019Guru - Experienced User
Redman1970
Apr 17, 2019Aspirant
Thank you!
