PaulBrink's avatar
PaulBrink
Initiate
May 11, 2020
No connection to router
I have just had new Virgin business wi fi Hitron CGNV4 router installed and my original residential router removed. When I try and set my original extender back up via WPS eventually every light turns...
  • plemans's avatar
    May 11, 2020
    Try factory resetting and re-installing it using the installation wizard and not wps.
    wps gets coded different between different manufacturers. And isp supplied devices are notorious for not implementing it properly.
    So try that route first.
