Pilot1
Nov 15, 2015Tutor
No Connection when SSID Broadcast is Off
I updated to firmwareV1.0.1.36_1.0.114. If I turn off SSID broadcast, I cannot connect my device. As soon as I turn SSID on, I can connect. Anyone else experience this?
Pilot1
Nov 16, 2015Tutor
Sorry, above is my first post - I upgraded the EX6100 wifi network extender. After the upgrade, I found that if I turn off broadcast SSID on the EX6100, my devices cannot connect, even though I had connected before with the EX6100 SSID broadcast turned on.
- nhannNov 16, 2015NETGEAR Employee Retired
Hi Pilot1,
Please confirm that only the SSID broadcast is off, leave the radios on.
Also on your computer, make sure these settings are checked
If it is still not working, you can try factory resetting your device. The firmware upgrade might have changed your settings.
