alogon60
Feb 25, 2021Aspirant
No hay conexion a internet
Hola, tengo un EX7000, usado como extensor wifi, también conectado por wifi al router, y llevo varios años que venía funcionando perfectamente. Pero al actualizar el firmware en el día de ayer, ahor...
Feb 25, 2021Guru - Experienced User
What router do you have?
What firmware version did you install?
How did you update? via wifi? using the app?
Might be worth reinstalling the firmware to the extender over a hardwired connection and then factory resetting it again. If something was corrupt in the firmware it can cause issues.
I'd also recommend avoid using the WPS method of install and use the installation assistant.
Photos have to be approved by a moderator so can take quite a while.
- alogon60Feb 25, 2021Aspirant
ROUTER EX7000
FIRMWARE 1.0.1.94
SE ACTUALIZO POR WIFI
- plemansFeb 26, 2021Guru - Experienced User
The EX7000 is the extender.
What router is it connected to?
- alogon60Feb 26, 2021Aspirant
EX7000, es extensor de red, conectado a otro extensor de Movistar España modelo Mitrastar Dual Wifi de Telefónica España conectado al router a través de cable de red Ethernet, ya que mi router no tiene Wifi.
